2.4ghz network becoming slower and slower
HarryJenkins
Message par HarryJenkins » 28 mars 2018, 07:35
Hello,
The past few weeks I have noticed that our 2.4 ghz network is becoming slower and slower for each day that passes. The 5ghz one is completely fine.
I tried to reset the router and even changed the network channel. I had 150mbps download and 100mbps upload for like a month ago. The 5ghz one has always been 350-380mbps download and 130 upload. Now I get like 30-40mbps download and upload on 2.4ghz. What should I do to fix this?
Please help.
I didn't find the right solution from the Internet.
References:-
https://www.cnet.com/forums/discussions ... nd-slower/
Business Intelligence Video
Thanks
Avatar de l’utilisateur
jpratpsft
Re: 2.4ghz network becoming slower and slower
Message par jpratpsft » 28 mars 2018, 08:16
Hi HarryJenkins,
Jérôme
First, you may check the network environment that may have changed, means that other networks around could have been installed recently and use the same channel as you use.
On 2.4GHz, there are only 3 non-overlaping channels, 1, 6 and 11.
If you use one of those, you may try one of the two others to see if the performances increase to your requirement level.
If you don't use one of those you may consider doing so.
If no other WiFi network was added recently, it could be another technology or even microwave ovens that use the same frequency bands.
Tools exist to detect other technologies using same frequency bands (chanalyzer for example).
Second, you may have had a damage or change on accessories or physical environment, RF cable partially broken, rust on connectors, antenna angle modified or reflection source added.
You may check the signal strength (RSSI) and compare it with previous values if you have it.
Third, you may check the network speed, it should be MCS20+ or more to reach the flow rate you mentioned, so check what is the current rate and see if it matches with previous values. If not, someone is preventing packets to propagate at that rate and forces the radio to decrease this rate. It is mainly due to parasites or heavy traffic on the same channel.
I hope this helps.
Jérôme
Tout d'abord, vous pouvez vérifier l'environnement réseau qui a peut-être changé, cela signifie que d'autres réseaux ont pu être installés récemment et utiliser le même canal que vous utilisez.
Sur 2,4 GHz, il n'y a que 3 canaux sans chevauchement, 1, 6 et 11.
Si vous en utilisez un, vous pouvez essayer l'un des deux autres pour voir si les performances augmentent à votre niveau d'exigence.
Si vous n'utilisez pas l'un d'entre eux, vous pouvez envisager de le faire.
Si aucun autre réseau WiFi n'a été ajouté récemment, il pourrait s'agir d'une autre technologie ou même de fours à micro-ondes qui utilisent les mêmes bandes de fréquence.
Des outils existent pour détecter d'autres technologies utilisant les mêmes bandes de fréquence (chanalyzer par exemple).
Deuxièmement, vous avez peut-être subi des dommages ou modifié des accessoires ou l'environnement physique, un câble RF partiellement brisé, de la rouille sur les connecteurs, un angle d'antenne modifié ou une source de réflexion ajoutée.
Vous pouvez vérifier la puissance du signal (RSSI) et la comparer avec les valeurs précédentes si vous l'avez.
Troisièmement, vous pouvez vérifier la vitesse du réseau, il devrait être MCS20 + ou plus pour atteindre le débit que vous avez mentionné, vérifiez donc quel est le débit actuel et voir si elle correspond aux valeurs précédentes. Sinon, quelqu'un empêche les paquets de se propager à ce rythme et oblige la radio à diminuer ce débit. Il est principalement dû aux parasites ou au trafic lourd sur le même canal.
J'espère que ça aide.
La cité de la peur
