Programmation d'un automate TSX P57203
Re: Programmation d'un automate TSX P57203
lts,
OUI
Meram
Message par Meram »
Pouvez vous expliquer un peu plus? car je trouve aucun tutoriel qui explique la mèthode!!!
merci d'avance.
En tapant simplement "tutoriel connexion automate PL7-Pro" sur Google on obtient en 5 secondes le lien suivant ou tout est expliqué : http://www.geea.org/IMG/pdf/Guide_PL7_P ... sferer.pdf
Meram
Message par Meram »
Merci beaucoup..
Meram
Message par Meram »
Pour transférer le programme du plc au TSX p57203, j'ai besoin d'un câble de connexion, est ce que je suis obligé d'utiliser le câble spécifique de shneider ou il suffit d'utiliser un câble standard ?
Meram
Message par Meram »
hello everyone!!
I have : dc integrator parker 590+ ;
plc shneider tsxp57203 upgradded;
a technology box option RS485 ( the control unit);
I need to control the integrator via this tech option, and I'm asking if anyone already worked with it??
I use unity pro to configure the plc and to communicate with the integrator!!
I'm asking for the method or the steps to follow to garranty a seccusseful communication with the device;
I've found some functions read_var write_var but I don't know if I'll need other functions..
thank you all!!!!!
_________________
A goal whithout a plan is just a wish!!
ivan
Message par ivan »
Hello. Please tell me I have a device that works schneider TSX P57203 SCADA Works on a program Monitor Pro Schneider Electric. But the program Monitor Pro has recently appeared on some problems And it does not work well, I wanted to reinstall the program Monitor Pro and change some of the controls on the control screen SCADA, but I could not install the program despite all attempts. please help.
ivan
Message par ivan »
Tell me please, in what programming environment can I program the modicon TSX P57203 SCADA. in another meaning, write the program SCADA for PLC modicon TSX P57203?
