Module de coloration syntaxique.
Posté : 26 oct. 2015, 16:31
par maxpeigne
Vous pouvez constater qu'une combo-box "Select code" est apparue juste au dessus du champs de saisi du message.
C'est la nouvelle fonction pour colorer le code que vous posterez (cela remplace le vert bien moche de l'ancienne balise code):
Code : Tout sélectionner
/* Blink without Delay
Turns on and off a light emitting diode (LED) connected to a digital
pin, without using the delay() function. This means that other code
can run at the same time without being interrupted by the LED code.
The circuit:
* LED attached from pin 13 to ground.
* Note: on most Arduinos, there is already an LED on the board
that's attached to pin 13, so no hardware is needed for this example.
created 2005
by David A. Mellis
modified 8 Feb 2010
by Paul Stoffregen
modified 11 Nov 2013
by Scott Fitzgerald
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used here to set a pin number :
const int ledPin = 13; // the number of the LED pin
// Variables will change :
int ledState = LOW; // ledState used to set the LED
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won't change :
const long interval = 1000; // interval at which to blink (milliseconds)
void setup() {
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
void loop()
// here is where you'd put code that needs to be running all the time.
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
unsigned long currentMillis = millis();
if(currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
previousMillis = currentMillis;
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
else
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
On peut remercier Brebiou d'avoir trouver cette extension !
Merci Brebiouuuuuuu 8-)
Re: Module de coloration syntaxique.
Posté : 26 oct. 2015, 16:34
par Brebiou
Par contre si vous cliquez "Aperçu", le bloc de code vous dira "Preview not available".
Pas de panique, en postant avec envoyer, le code est bien dans la balise
Et de rien maxpeigne ;)
Posté : 27 oct. 2015, 05:52
par Bernardo59
Ca n' a plus l'air de fonctionner non ?
Posté : 27 oct. 2015, 06:11
par maxpeigne
Test:
void loop()
// blink the LED.
ledState = HIGH;
else
ledState = LOW;
Posté : 27 oct. 2015, 06:12
par maxpeigne
@bernardo: Tu n'arrives pas à les lires ou à les poster?
Posté : 27 oct. 2015, 07:08
par Bernardo59
J'ai ça moi, c'est ça qu'il faut voir ?
Posté : 27 oct. 2015, 07:28
par maxpeigne
En fait par defaut le code est compacté, il faut cliqué sur "Expand/Collapse" pour le voir.
Posté : 27 oct. 2015, 08:03
par Bernardo59
Oula oui en effet !
Il faut le voir ! :shock:
