hello
i am an electrical engineering student, i am currently doing an internship and my task is to repair a wheel press machine
the problem is that the cpu 315 2DP M/S 2AF03 sf RED light is on
the problem is there is no MPI port to connect USB adapter to dignose the cpu
how can i know whats the problem with the system
help
cpu system fault
- Bernardo59
Re: cpu system fault
Hello,
I think U need to disconnect an MPI port to make a diagnosis, no ?
Otherwise, if U have and Ethernet port, you can check ur CPU.
The best way is probably to find an available MPI port to connect your computer.
If you can't do this, then check the hardware. My opinion is that it's probably caused by an analog sensor issue.
You can also check the CPU manual, that should help
https://support.industry.siemens.com/cs ... n&lc=fr-FR
le forum devient international , je réponds pas vu que connais mal le matos "teutons" et vu que j'entrave que couic en "rosbif"
quand je parle en rosbif à des anglais, ils me comprennent pas. Ils sont tellement cons qu'ils ne comprennent même pas leur propre langue.
itasoft a écrit : ↑16 sept. 2018, 15:36 slts,
Hi,
I think like Profnov A, it may be an analog defect.
