How to program TSX17 PLC
Hi! I have a TSX 17 PLC and i Would know how to program it from virtual machine. I have installed OS2 warp 3 and if i try to install XTEL archive downloaded from the net , the installation ends always with an error. If i try to install single PL7 2 or PL7 1 software it results into a 251 error or invalid license error. Can someone help me?
- Bernardo59
Re: How to program TSX17 PLC
Hi fedant09 and welcome it !fedant09 a écrit : ↑14 mars 2020, 18:39 Hi! I have a TSX 17 PLC and i Would know how to program it from virtual machine. I have installed OS2 warp 3 and if i try to install XTEL archive downloaded from the net , the installation ends always with an error. If i try to install single PL7 2 or PL7 1 software it results into a 251 error or invalid license error. Can someone help me?
I think that you downloaded a bad archive of OS2. Where did you download it?
Best Regards,
MP me if you want OS/2 archive with patch for Xtel and pl7-1 exe.
Hi, thank youBernardo59 a écrit : ↑16 mars 2020, 08:03Hi fedant09 and welcome it !fedant09 a écrit : ↑14 mars 2020, 18:39 Hi! I have a TSX 17 PLC and i Would know how to program it from virtual machine. I have installed OS2 warp 3 and if i try to install XTEL archive downloaded from the net , the installation ends always with an error. If i try to install single PL7 2 or PL7 1 software it results into a 251 error or invalid license error. Can someone help me?
Best Regards,
I initially dowbloaded the first OS2 installation image i found, but I also downloaded some image of virtual machines that i found on this forum, but the error is the same...
AlainPassautomation
- Apprend le binaire
Hello,
There is no PL7.1 In XTEL, To program your plc in PL7.1, you need a programming pocket.
you can also add an prorgramming pl7.2 with or without Grafcet option in the tsx.
then you can used PL7.2 in dos version or os2 version
je réponds pas vu que j'entrave que couic en "rosbif" LOL
